Guest johnlwarence Posted June 28, 2007 Share Posted June 28, 2007 i have a problem with my driver side window, it doesn't close all the way up! up to about 5 mm from the top it starts to tick as if some teeth are slipping on the mech. i have a MK.5 95 cab but the window mechanism is the cantilever system. i have looked everywhere for a replacement and even tried find-a-part, but still no joy the major problem is that water is coming off the roof and onto my drivers seat. i have managed to temporally fix it by pulling the window up fully with my hands but i can still hear wind noises can anyone help me find a new mechanism or if anyone has had a similar problem and fixed it THANKS GUYS!!! Link to comment Share on other sites More sharing options...
Guest an1mal_69 Posted July 2, 2007 Share Posted July 2, 2007 sounds like you need a new mechanism..only fix really. i got a passenger one off ebay..keep your eye out Link to comment Share on other sites More sharing options...
Guest enzo Posted July 2, 2007 Share Posted July 2, 2007 im sure ive read on here about simaler prob where it can b adjusted might b wrong m8 but have a look about Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted July 3, 2007 Share Posted July 3, 2007 Could always try getting it looked at by a Car Auto Glass fitter, not Auto Glass as they are ripoff merchants by me, try a private firm !!! Hope you get it sorted !!! Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted July 3, 2007 Share Posted July 3, 2007 Have you tried taking your door card off and adjusting the height the window sits at? Did it suddenly stop going all the way up or has it always done this? Link to comment Share on other sites More sharing options...
Guest johnlwarence Posted July 3, 2007 Share Posted July 3, 2007 managed to find a new mechanism thank you everyone hope your all having a great day :Chris: Link to comment Share on other sites More sharing options...
Guest yidcab Posted July 4, 2007 Share Posted July 4, 2007 hi, do you know how to adjust the height the window sits at ? Link to comment Share on other sites More sharing options...
Guest ppc220779 Posted July 5, 2007 Share Posted July 5, 2007 managed to find a new mechanism thank you everyone hope your all having a great day :Chris: Ha! Havin the same prob myself at the mo. Started a few days ago. Had a quick feel behind the door and it feels like there's a few teeth chewed up on the toothed coggy mechanism bit. is that the only bit that needs replacing? an where did you find ya replacement? Link to comment Share on other sites More sharing options...
Vincygav Posted July 18, 2007 Share Posted July 18, 2007 It can not be adjusted in that sense. The problem what has happened with this is that the teeth on the regulator arm is worn at a certain point near the top. So when the gear on the motor reaches this point the teeth can not grip as it has no traction,so the window would just drop back down. My cabby was like this one I bought it from someone last year. I ended up buying a aftermarket electric motor and regulator on ebay. The regulator on these are adjustable unlike the Ford one, so you can push out the top end height on it. Link to comment Share on other sites More sharing options...
