Guest millmoor2007 Posted June 25, 2007 Share Posted June 25, 2007 hi front footwell full of water add new roof fitted but still the same i seem to have a gap on the door window but will not go up any more i think thats were it my be getting in help plzzzzzzz :throw: Link to comment Share on other sites More sharing options...
Guest millmoor2007 Posted June 25, 2007 Share Posted June 25, 2007 sorry about this iys a mk 5 Link to comment Share on other sites More sharing options...
Guest markeyboy Posted June 25, 2007 Share Posted June 25, 2007 take ya door card off, there some bolts that hold the windo mechanism in place, loosen them and move it up and tighten, should work out ok m8 Link to comment Share on other sites More sharing options...
Guest southern lass Posted June 25, 2007 Share Posted June 25, 2007 Soz 2 hear bout yr probs...I av a mk5b with same prob. http://www.escortcabrioletclub.co.uk/forum...pic=9116&hl GOOD LUCK on gettin it sorted, S.L Link to comment Share on other sites More sharing options...
Guest a93droptop Posted July 22, 2007 Share Posted July 22, 2007 a common problem with escorts is the fuse box, in a lot of cases its because of water ingress from the windscreen rubber at the bottom and dripping on the fusebox and corroding the connections! this maybe worth a check to see if the fusebox is wet if so this might be ya problem, also if its leaking from the join between the roof and the front pillar try adjusting the door to close a little tighter, hope this helps. Link to comment Share on other sites More sharing options...
