Guest pipefitter Posted June 16, 2007 Share Posted June 16, 2007 My son is having a lot of problems with his Mk6 cab.Its been fine up untill a few weeks ago. His car runs OK for a few days then completly cuts out and is unable to restart only with jump leads.Bought and fitted a new battery on the advise of the breakdown recovery driver about a month ago.Its run Ok up till afew days ago , started cutting out again.Fitted a second hand alternator on the advise of another breakdown recovery driver 2 days ago. Problem still happening.It, in his own words chugs then cuts out.when I was with him after his first breakdown it sounded like the starter motor was jamed it clicked when he turned the ignition key to try and start.Any help would be gratefull. Link to comment Share on other sites More sharing options...
Guest markeyboy Posted June 16, 2007 Share Posted June 16, 2007 sounds like the alternator is playing up, same thing happened to mine, check the main charging lead from the alternator to the battery, if not chect to see if you havnt put another duff alternator on Link to comment Share on other sites More sharing options...
Guest robman1 Posted June 17, 2007 Share Posted June 17, 2007 change the starter motor i recon n check all the connections to it all. is the alternator belt properly tensioned too? Link to comment Share on other sites More sharing options...
Guest qtronix Posted June 17, 2007 Share Posted June 17, 2007 if you have changed the batt and the alternetor the batts still going dead and its still happening it could be a bad earth adam Link to comment Share on other sites More sharing options...
