Guest Maz Posted June 10, 2007 Share Posted June 10, 2007 Got lighting problems, assume our Mk5 has a Dim dip unit but not found it yet!! Would appreciate any advice as to the location and just to confirm it does/not have one Thanks Link to comment Share on other sites More sharing options...
Guest robman1 Posted June 18, 2007 Share Posted June 18, 2007 it would be on your switch i believe i.e the indicator unit, buy a new one if i dnt work Link to comment Share on other sites More sharing options...
Guest Maz Posted June 19, 2007 Share Posted June 19, 2007 It should be somewhere under the bonnet (if it has one) It's a block of resistors that puts dipped headlights on dim (hence dim dip) when sidelights are operated. In case a sidelight bulb blows. Don't think they have them on newer vehicles Link to comment Share on other sites More sharing options...
Guest diane Posted June 19, 2007 Share Posted June 19, 2007 It should be somewhere under the bonnet (if it has one) It's a block of resistors that puts dipped headlights on dim (hence dim dip) when sidelights are operated. In case a sidelight bulb blows. Don't think they have them on newer vehicles Thought all cars had bonnets !! lol Link to comment Share on other sites More sharing options...
