Guest JonnyP Posted February 28, 2017 Share Posted February 28, 2017 Hi, can some one point me in the right direction of the idle speed problem on my 89 XR3i? It starts and idles from cold at about 1200 - 1500 revs but as she warms idles at a constant 2000 revs, I've read through a few of the other idle speed related problems but thought I'd throw this out there myself. Is it the Idle control valve and if so where is it located on the MK4 model or could it be something else? She drives fine apart from exceptionally high revs at all times. Many Thanks Jonathan Quote Link to comment Share on other sites More sharing options...
jinks Posted February 28, 2017 Share Posted February 28, 2017 hi chap you got efi or mfi cheers john Quote Link to comment Share on other sites More sharing options...
Guest JonnyP Posted March 2, 2017 Share Posted March 2, 2017 hi chap you got efi or mfi cheers john Hi John, Thanks for your reply, It's the last of the MFi engines Best Jonathan Quote Link to comment Share on other sites More sharing options...
jinks Posted March 2, 2017 Share Posted March 2, 2017 hi jon not to shore with mfi not big fan they have problems with the metering unit mine efi some one befor me had drilled out the tps sensor on throtle body so it would tick over high , check the flap on it Quote Link to comment Share on other sites More sharing options...
jinks Posted March 2, 2017 Share Posted March 2, 2017 check your air pipes might be sucking in air that will cause high revs mate look at the vacuum pipe from service to manifold Quote Link to comment Share on other sites More sharing options...
jinks Posted March 2, 2017 Share Posted March 2, 2017 just spoken to mate said check the cold starter solenoid might be stuck think it on the inlet Quote Link to comment Share on other sites More sharing options...
Guest JonnyP Posted March 8, 2017 Share Posted March 8, 2017 just spoken to mate said check the cold starter solenoid might be stuck think it on the inlet Great, Thank you Mate, will check that out. Many thanks for the help. Jon Quote Link to comment Share on other sites More sharing options...
