Guest Sonniek2006 Posted June 6, 2016 Share Posted June 6, 2016 hi i looking for some help or more like information really i have a mfi rs turbo engine in my cabby and tonight i took it out for the first time this year after about 5 miles developed a problem it dropped down to 3 cylinders and lots of blueish smoke i seem to lost compression in that bore i have a spare engine but its efi not mfi can i just swap them over ????? Quote Link to comment Share on other sites More sharing options...
Guest username Posted June 10, 2016 Share Posted June 10, 2016 (edited) Before going to the trouble of a whole engine swap, try to find exactly why you lost that cylinder. have you done an actual compression test? if not that's the first thing & post up results. Also, if you have any low readings on the first test, drop about a teaspoon full of oil down the plug hole and test again (wet test). if things improve significantly then it points to rings/bores. If the car has stood for a while or missed a service it could be as simple as a sticky valve/lifter or piston ring (or maybe even oil from stem seals fouling up a spark plug), a lot of easier and quicker things to sort than swapping the engine anyway first things first, let's have a butchers at your dry & wet comp test results please Edited June 10, 2016 by username Quote Link to comment Share on other sites More sharing options...
