Mk4 Relay Mystery
Guest Ben Calverley
Guest Ben Calverley
Hi guys, I've lost power to fan, heating, indicators, wipers and reverse lights. Had relays checked and the big gray one under the bonnet doesn't work what does this do? And also the black one under the dash doesn't work either again what's this one do? And finally under the dash where the black one is there is also a purple (working fine) and a green, well the space for a green but I don't have a relay in it? Why? And what should this do? I've looked online can't find a thing. FYI all other fuses and relays working fine
green could be for turbo model ? have you got a haynes manual? it should tell you in there theres a link on here for a pdf copy - go to downloads and then service manual
