Relays And Fuses
Guest gibby
Having trouble getting hi beam to work.is there a pic on here of mk4.fuse box.showing wot fuse does what n wot relay does wot as i believe my cover isn't original one.
Thanks
These should be under the bonnet on the driver's side.
Fuse 9 is LH high beam 10 amps
Fuse 10 is RH high beam 10 amps
All I can find in the Haynes is that the relay is number 91.
Sorry, no pics.
Andy
