Guest benny Posted May 2, 2015 Share Posted May 2, 2015 Does any one know out there, does the 220mm mfi fly wheel have a recess and if so, if its skimmed will this cause clutch slip, I pretty much have no 3/4/5 gear on boost, had a stage one clutch black diamond fitted, it slipped, tried s paddle clutch it would work with the pressure plate from the stage1 even though black diamond assured me it would, but the fly wheel had been skimmed and had no recess upto now I'm almost a 1000 put of pocket and still have s slipping clutch Quote Link to comment Share on other sites More sharing options...
welshlad Posted May 3, 2015 Share Posted May 3, 2015 clutch cable stretched maybe? Quote Link to comment Share on other sites More sharing options...
Guest benny Posted May 7, 2015 Share Posted May 7, 2015 No that's fine, even replaced the clutch ratchet, if the flywheel should have a recess and now doesn't the clutch won't sit properly against the pressure plate Quote Link to comment Share on other sites More sharing options...
