Guest chris.lord32@hotmail.co.uk Posted February 2, 2015 Share Posted February 2, 2015 Hi all - reliving my k reg xr3i cabriolet 130bhp youth days now having not long bought a 1997 p reg mk cabriolet ghia in Jewel Violet 93 ! Roof pump was dry so have filled itwith roof fluid fuse in footwell good and relay there too power to switch and switch tested and working fuse in boot ok and 3 relays all green the same present too tested pump with a 12v low amps battery and its working fine tested power on a relay to ground and 12volts present key in ignition turned without engine running and = NOTHING HAPPENING when pressing the switch !!!! ANY IDEAS gratefully received please !!!!! or diagrams or confirmation of correct relay informaion ! Chris Quote Link to comment Share on other sites More sharing options...
Guest Terence Mears Posted February 2, 2015 Share Posted February 2, 2015 Do the roof ignition mod its posted in electrical I think that will fix it Quote Link to comment Share on other sites More sharing options...
Guest chris.lord32@hotmail.co.uk Posted February 2, 2015 Share Posted February 2, 2015 Hi Terence - had spotted that feed when trawling through the various post on roof issues. Didn't want to alter the originality of the workings of the car to fix but am eager to get the roof working as its so close to being !!! I'm going to strap a wire to good Earth on the car to the blue wire on the switch temporary to see if it cures and if so make it a permanent fix ? ! - cheers Quote Link to comment Share on other sites More sharing options...
