Guest suffolk04 Posted July 20, 2014 Share Posted July 20, 2014 Got loads of wobble on the drivers door window,(can rock it back and forward) looks like the rubber chanel is worn and the plastic bit on top of the door. What are theses called and does anyone have any for sale. I've been trying to fix this water leak for months, brought door rubbers,handles and just had new mohair roof fitted, so hopefully someone can help, and I can start using the cab Quote Link to comment Share on other sites More sharing options...
Guest ANDYA Posted August 17, 2014 Share Posted August 17, 2014 See this response I made, it may help you with the door rubbers trim. 1986 Xr3I Door/qy=Uarter Wondow TrimStarted by wcelliot, Jun 07 2014 11:03 PM Hope it helps Quote Link to comment Share on other sites More sharing options...
Guest ANDYA Posted August 17, 2014 Share Posted August 17, 2014 Sorry that didn't work here's the info; Here's a great trick that will allow you to replace your front door trims for free! Remove the right hand inner door panel. Once you've done this, if you look along the top of inside of the door, you'll see there is a pristine rubber trim where it meets the glass. This will be a perfect fit for the outside of the left hand door. You can do the same with the left hand door. The old external perished seals can be placed back in their corresponding inner edges. It's basically a swap. The perished seals will be hidden when you put the door trims back on. I did this 4 years ago and they still look great. Let me know how it goes. All the best, Andy Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted August 18, 2014 Share Posted August 18, 2014 I don't think I described the right seal, it's the vertical one that goes into the metal door runner Quote Link to comment Share on other sites More sharing options...
Guest ANDYA Posted August 18, 2014 Share Posted August 18, 2014 Here are door end rubbers for the back end of the door; http://www.ebay.co.uk/itm/escort-mk3-4-xr3i-cabriolet-door-end-rubbers-/311023722495?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item486a755fff Here are the vertical window rubbers you referred to; http://www.ebay.co.uk/itm/ESCORT-MK3-4-CABRIOLET-XR3I-RS-TURBO-FRONT-DOOR-QUARTER-WINDOW-RUBBERS-/121400382110?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c4406d29e Some more; http://www.ebay.co.uk/itm/ESCORT-MK3-4-CABRIOLET-XR3I-RS-TURBO-PAIR-OF-FRONT-DOOR-WINDOW-RUNNERS-/121375568750?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c428c336e I can't find the bits that go on the top of the frame Hope this helps, should stop the rattle at least! Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted August 18, 2014 Share Posted August 18, 2014 Thanks for the links? Ive brought the ones in the 2nd link before, but there the ones on the quarter glass and not door window. Quote Link to comment Share on other sites More sharing options...
