Guest baldstumpy Posted May 21, 2014 Share Posted May 21, 2014 Can someone tell me where its located and what colour it is please, No fuel pump noise so I need to start with this to try and fix it Quote Link to comment Share on other sites More sharing options...
Guest Older and wiser Posted May 21, 2014 Share Posted May 21, 2014 Have you had this problem since having the car jacked up? there is a switch under the spare tyre in boot that is white and needs depressing if car has had a bump or sudden movement, it is a fuel cut of switch. Quote Link to comment Share on other sites More sharing options...
welshlad Posted May 22, 2014 Share Posted May 22, 2014 good point older and wiser, otherwise its a small yellow one under the dash right hand side if it is a relay prob try and bridge terminals 30 and 87 witha peice of suitable wire to see if the pump primes/works (obv with ignition on) Quote Link to comment Share on other sites More sharing options...
