Guest millie5506 Posted May 7, 2014 Share Posted May 7, 2014 Hi Guys, new to this i have a fuel pump problem which i think i have found out the fault it's the coil pulse feed the question is does this feed go to the dash first from the coil to do the rev gauge? or does it go to the relay then to the dash as my rev gauge works what my problem is the relay will do the first 5 seconds but when i start it cuts out i have put a new one in still does the same so i think its waiting for the pulse signal to come back from the coil possible break in cable? thanks dave Quote Link to comment Share on other sites More sharing options...
Guest millie5506 Posted May 7, 2014 Share Posted May 7, 2014 sorry it a 1985 C reg MK3 Escort Cabriolet Quote Link to comment Share on other sites More sharing options...
