Guest escortmatt86 Posted May 4, 2014 Share Posted May 4, 2014 Ford escort xr3i 1.6mfi 1989 g When I fill the car the gauge only shows 3 quarters full new gauge fitted So ruled out Used sender unit fitted to tank so ruled out Can there be any thing in the tank that may stop the float going all the way up? Thanks Quote Link to comment Share on other sites More sharing options...
lenny f Posted May 4, 2014 Share Posted May 4, 2014 Sure bottom of tank hasn't been pushed up a touch Quote Link to comment Share on other sites More sharing options...
Guest steve356 Posted May 5, 2014 Share Posted May 5, 2014 I had the same fault on my mfi cab, took the tank out fitted a replacment float switch , tank in the end changed the fuel gage and solved the fauly : ) Quote Link to comment Share on other sites More sharing options...
