Guest cossy1995 Posted April 14, 2014 Share Posted April 14, 2014 would anyone know how to bench check roof relays in a 1990 xr3i Quote Link to comment Share on other sites More sharing options...
Guest Alvaro Posted September 29, 2014 Share Posted September 29, 2014 Usually to check a relay you could apply the suit voltage to the coil of the relay. The voltage should be written at the surface of the relay. Probably it's 12V from the battery. You can hear if the relay is moving. If you have a multimeter also you can check if contactcs are closed when they must be. (sorry for my english) Quote Link to comment Share on other sites More sharing options...
