welshlad Posted September 9, 2013 Share Posted September 9, 2013 Hi guys Does anyone know were the spotlight wiring terminates under the dash etc? i had power on the wiring loom momentarily then it blew the bulb in my snap on circuit tester. Tried all the fuses and they are ok Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted September 9, 2013 Share Posted September 9, 2013 The spotlights operate when main beam is on so the spotlight live feed is just in front of the O/S/F strut top & there is a relay in the fuse box (sorry I cant remember which one at the moment) Quote Link to comment Share on other sites More sharing options...
welshlad Posted September 13, 2013 Author Share Posted September 13, 2013 fuses and relays are fine, had power on spotlight loom momentarily and now its gone wire is ok ie it hasnt soaked up any water and corroded si im a bit confused as to why its getting no live feed hmmmm? gona have to wire them straight to the headlights feed or make a new loom with a relay etc Quote Link to comment Share on other sites More sharing options...
Guest chucky dozza Posted December 3, 2013 Share Posted December 3, 2013 How did you fix this as mines same but main beam fine Quote Link to comment Share on other sites More sharing options...
