Guest Stally08 Posted August 27, 2013 Share Posted August 27, 2013 My passenger foot well carpet is soaking wet, any ideas what it could be? i thought maybe the pollen filter is it has one? Cant be the roof as the roof is new and has never leaked before. Any help is much appreciated Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 27, 2013 Share Posted August 27, 2013 Rotten battery tray is most likly cause of this Quote Link to comment Share on other sites More sharing options...
Guest big g Posted August 27, 2013 Share Posted August 27, 2013 take the battery out and give it a good prod around there very common spot for water ingress Quote Link to comment Share on other sites More sharing options...
Guest Stally08 Posted August 27, 2013 Share Posted August 27, 2013 Cheers guys to be honest the battery tray is in pretty good nick but ill have a prod around see if its rotten Quote Link to comment Share on other sites More sharing options...
Guest Tony8020 Posted August 28, 2013 Share Posted August 28, 2013 it could be the door seal, I had the same issue on the drivers side, it was the seal so I got a replacement from www.sealsdirect.co.uk and it sorted the issue. if you've had a new roof it might be worth adjusting the nut on the release handles, battery tray is usually the main cause though Quote Link to comment Share on other sites More sharing options...
Guest xr3idan Posted September 24, 2013 Share Posted September 24, 2013 it could also be water running from the roof, round the seal and down the window and out of the bottom of the door, simple fix if it is, just adjust the window up to meet the roof snuggly. Quote Link to comment Share on other sites More sharing options...
welshlad Posted October 6, 2013 Share Posted October 6, 2013 ooo havnt had a leak for a long time touch wood lol Quote Link to comment Share on other sites More sharing options...
