Got The Roof To Go Down ? But Wont Go Up ?
Guest martboltonuk
Guest martboltonuk
Well I read the posting on here from Ollie, and ta daaaaah it went down but wont go up ? anyone any ideas, and is there a get out of jail card for getting the roof back up manually ?
Mart
Guest Lee81
Turn the tap on the pump. This will allow you to raise the roof by hand. It in effect creates a bypass in the hydralic system.
You probably have a faulty relay as theres two. switching them around will probably make the roof go up but not down
Guest varnie3i
A friend of mine had a roof that was converted from manual to hydrolic and it had two little safety catches in the back. There were two little levers near the rear speakers that needed to be pushed down as to release the roof. Nut sure if this helps but it's worth looking.
  • 3 weeks later...
Guest Lee81
If you have a hydrolic roof these latches need removing as you don't need them. The hydralic system holds the roof down. On cars that came from the factory these were removed
