Guest Champy13 Posted March 2, 2013 Share Posted March 2, 2013 Is there a gauze or such like in the rocker cover?? I have pressure issues which as far as i can make out can only come from there. I presume the following, as looking at the engine from the front of the car... The pipe from the back/ the sump on the right hand side, which is connected to the rocker cover should blow air/vapour as it seems to be pushing air out well? and then the Left hand side pipe connected to the small inline filter, should blow vapour to be recirculated through and back into the system, isnt doing anything, not a bit of air?? When i removed the right hand side pipe i got air blowing back out of the rocker cover... I hope i have explained it but im soo confused whats causing the oil leaks when the engine is spot on, been compression tested and no oily plugs or smoke when it starts. I have checked all the pipes for the oil system but it still drips from the end of the air box, more so after a run.. Can anyone varify this and also tell me the best way and chemicals to clean the gauze if there is one as mines either really really clogged up or blocked?? Quote Link to comment Share on other sites More sharing options...
Guest Champy13 Posted March 2, 2013 Share Posted March 2, 2013 apologies for posting twice, fancy mouse feel free to delete one ) Quote Link to comment Share on other sites More sharing options...
