Guest lipgloss Posted August 29, 2012 Share Posted August 29, 2012 Hi i have no back lights or brake lights could this be a fuse or electrical...i do have indicators Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted August 29, 2012 Admin Share Posted August 29, 2012 Maybe a bad earth? Is it a MK3/4 or later? Quote Link to comment Share on other sites More sharing options...
Guest lipgloss Posted August 29, 2012 Share Posted August 29, 2012 It is a Mk4 that has had huge electrical problems so much so my mechanic is now bald !! Quote Link to comment Share on other sites More sharing options...
Guest lipgloss Posted August 29, 2012 Share Posted August 29, 2012 I think it is a Mk4 it is on an M Plate..... being blonde cant see where it says it on the log book Quote Link to comment Share on other sites More sharing options...
Guest black xr3i Posted August 29, 2012 Share Posted August 29, 2012 check fuses under bonet Quote Link to comment Share on other sites More sharing options...
Guest nellyboy Posted August 29, 2012 Share Posted August 29, 2012 Hi im new to the site and i will try and help...i have a mk5 M reg cab..starting with the basics check the bulbs..then if you unplug the wireing connectors and check all the prongs (five or six from memory) are all inserting correctly and not missing contact when inserted...then yes check fuses..see if that fixes it..if not its a wireing/earth fault..keep in mind the fuseboxes play up due to moisture on mk5`s.. Quote Link to comment Share on other sites More sharing options...
Guest lipgloss Posted August 29, 2012 Share Posted August 29, 2012 Aww thanks guys thats really awesome that you all are tryin to help me i shall do this tomorrow .... i promise i can.... have done a few bits myself ! am frightened to ring my mechanic as he is losing the will to live although his pockets are lively LOL Quote Link to comment Share on other sites More sharing options...
Guest nellyboy Posted August 30, 2012 Share Posted August 30, 2012 well good luck...try going back to when the problem arose...ive known people put a single element bulb in a twin element holder..sometimes its the small things causing major problems..hope you get it sorted... Quote Link to comment Share on other sites More sharing options...
Guest lipgloss Posted August 31, 2012 Share Posted August 31, 2012 Thank you all..... but bulbs all fine and fuses good too ...drove it home this afternoon without stopping !! was quite an adventure anyone know a good electrician in the south Quote Link to comment Share on other sites More sharing options...
Guest black xr3i Posted September 2, 2012 Share Posted September 2, 2012 were in the south?? Quote Link to comment Share on other sites More sharing options...
Guest black xr3i Posted September 2, 2012 Share Posted September 2, 2012 are you i mean lol Quote Link to comment Share on other sites More sharing options...
Guest lipgloss Posted September 4, 2012 Share Posted September 4, 2012 got it sorted now ......thank you all it was the Main Switch ..... luckily i have one saved for spares !!! Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted September 5, 2012 Admin Share Posted September 5, 2012 Glad you got it sorted :-) Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted September 6, 2012 Share Posted September 6, 2012 if you have any more probs i know a good garage in the south well depends on where abouts you from Quote Link to comment Share on other sites More sharing options...
