Guest med75 Posted August 25, 2012 Share Posted August 25, 2012 ok i have a mk6 escort ghia cab 3 of the windows are working ok but the driver side window goes down with the switch pressed but it does not go up i have changed the swith and the relay under the center console and the motor works when i put a car battery to it so it goes up and down then when i put a multi meter in the plug for the motor it only shows voltage when i press it one way and at the same time the relay clicks like mad when its all connected back up when im trying to close the window any ideas anyone i would very much appreciate it thx in advance Quote Link to comment Share on other sites More sharing options...
