Guest black xr3i Posted August 12, 2012 Share Posted August 12, 2012 hi need help ....... weres the fuel pump relay on a 1988 mk4 cabbie ??? the prob is the fuel pump works for the 1st few miles then cuts out ?? i leave it for a bout a min and it works again????? cant work it out is it the pump or the relay?? thanks andy Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 12, 2012 Share Posted August 12, 2012 Its the relay. it will need to be soldered inside so it works as it should. Look for pink/purple relay up under the dash in the drivers footwell. It will be in bank of relays there Quote Link to comment Share on other sites More sharing options...
Guest black xr3i Posted August 13, 2012 Share Posted August 13, 2012 arr right witch bit needs solderin?? cus can do that bit my self Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted August 13, 2012 Admin Share Posted August 13, 2012 Open the relay up and look for dry joints, or go over each joint with fresh solder Paul Quote Link to comment Share on other sites More sharing options...
Guest black xr3i Posted August 13, 2012 Share Posted August 13, 2012 cheers paul will do laters then founrd the relay so jus have to wip it out Quote Link to comment Share on other sites More sharing options...
