Guest tazanddave Posted August 12, 2012 Share Posted August 12, 2012 The reverse lights on my cabby arent working.cant find fuse in fuse box.any help please. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 12, 2012 Share Posted August 12, 2012 More than likly be the reverse gear switch located on the gearbox. If a fuse were blown you wouldn't have any lights working as its all powered through the same fuse. Not a big job and easy to test if it is the problem using a piece of wire between the terminals. Also theres no requirement to have reverse lights for MOT etc. Quote Link to comment Share on other sites More sharing options...
Guest tazanddave Posted August 12, 2012 Share Posted August 12, 2012 How do u check with a bit of wire? Thanks Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted August 13, 2012 Admin Share Posted August 13, 2012 Just unplug the plug from the sensor and put a piece of wire across the 2 terminials in the plug. Make sure the ignition is switched on. If youe rear reversing lights come on then you know its the sensor in the gearbox. Very easy to replace. Paul Quote Link to comment Share on other sites More sharing options...
Guest tazanddave Posted August 14, 2012 Share Posted August 14, 2012 thanks for help it is all sorted now Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted August 14, 2012 Admin Share Posted August 14, 2012 What was it ?? Quote Link to comment Share on other sites More sharing options...
