Guest Mejojo Posted August 9, 2012 Share Posted August 9, 2012 Roof just stopped working. When I press the switch the green relay in the boot clicks. N the other green one seems quiet. No wurring noise just the clicks. Please help. Jojo Quote Link to comment Share on other sites More sharing options...
Guest Alanman Posted August 9, 2012 Share Posted August 9, 2012 Short term fix. open the valve (little tap thing) on side of the pump and at least you'll be able to use the roof manually until you can work out what's wrong. The relay sound like its sticking or could be a fuse. You'll need someone to check these that know about electrics. At least if you turn the valve you can still use it. Quote Link to comment Share on other sites More sharing options...
Guest Mejojo Posted August 9, 2012 Share Posted August 9, 2012 Cheers mr alanman. Yeah iis gotta be something in the wiring n that's well beyond my knowledge. Manual roof for ford fair I guess. Something shitty happens every time we take him to show. Ah well eh. Thanks again. Quote Link to comment Share on other sites More sharing options...
