Guest Willey1802 Posted May 19, 2012 Share Posted May 19, 2012 Hi all, I need to replenish my power roof fluid, but don't want to pay some £25 - £30 for Ford's fluid when i have been told that you can use power steering fluid. Does anyone know if this is correct and if so what grade of fluid to use, as apparently there are 2 grades. Any advice appreciated Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 19, 2012 Share Posted May 19, 2012 I just used Comma red pas fluid. works fine and never had any probs Quote Link to comment Share on other sites More sharing options...
Guest Willey1802 Posted May 20, 2012 Share Posted May 20, 2012 Thanks for reply, will give it a go. What does pas stand for though? Quote Link to comment Share on other sites More sharing options...
Guest milwr Posted May 20, 2012 Share Posted May 20, 2012 Power Assisted Steering ....Milwr Quote Link to comment Share on other sites More sharing options...
Guest Mejojo Posted June 4, 2012 Share Posted June 4, 2012 Best to use proper roof stuff or hydraulic jack mineral fluid. Some power steering fluids can be corrosive to the plastic reservoir and over time create cracks and leaks. The reservoirs are a bitch to find on their own so you have to buy a full pump just for that part. VW do a fluid for their convertibles. Can be bought from VW dealers and it's cheaper than fords. If the pas stuff is natural then it should be ok but check the label. Quote Link to comment Share on other sites More sharing options...
