Guest Rustler Posted May 17, 2012 Share Posted May 17, 2012 My "FOOTWELL" lights seem to take ages to extinguish,at least 8 to 10 minuits,from shutting either door. This situation is prominent when the car doors are opened , and then closed, without the ignition key in situe. Is this time lapse usual or is there a prob' with a realay.?....if so , which realy should be suspect. ? ................................Rustler............................ Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted May 17, 2012 Admin Share Posted May 17, 2012 I thought they should just slowly fade over a few seconds not minutes Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted May 17, 2012 Share Posted May 17, 2012 aint they on a timed relay similar to the intermitent wiper speed etc. bet its just the relay packing up. or you might have a dodgy door switch in the gap where the hing is. try opening a door and hold the button in and see what happens maybe as it may be failing. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted May 18, 2012 Share Posted May 18, 2012 aint they on a timed relay similar to the intermitent wiper speed etc. bet its just the relay packing up. or you might have a dodgy door switch in the gap where the hing is. try opening a door and hold the button in and see what happens maybe as it may be failing. Thanks both......I'll give that a try... If not will have to change the relay sometime....... ................................Rustler......................"The Oldest Cabbier"................ Quote Link to comment Share on other sites More sharing options...
