Guest gavin1984 Posted May 11, 2012 Share Posted May 11, 2012 Hi wondering if any macanical minded people could help me. Water pump is peeing out water but engine struggles to start and when driving cuts out and engine shakes like hell, does this sound like head gasket gone to? Please help Quote Link to comment Share on other sites More sharing options...
Guest Alanman Posted May 11, 2012 Share Posted May 11, 2012 If the waterpump has colapsed your belt could now be loose and maybe jumped a tooth casuing it to struggle. 1 tooth out on the belt shouldnt hurt the engine but it would give the symptoms you talk of. It's sould lumpy if this has happened. I'd get it looked at before you do more damage. One way to check if the headgasket has gone is to see if oil filler is creamy. That would show if there's water in the oil. Quote Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted May 11, 2012 Share Posted May 11, 2012 Hi thanks for the reply, I've checked the dip stick oil is still normal colour just smells a little burnt Quote Link to comment Share on other sites More sharing options...
Guest will_s1cab Posted May 11, 2012 Share Posted May 11, 2012 fink Al meant check the cap where u top the oil up, if it has white "mayonaise" looking gunk water is mixing with oil sumwhere. Quote Link to comment Share on other sites More sharing options...
