Guest roitman1995 Posted May 6, 2012 Share Posted May 6, 2012 my 1987 cabb runs sweet as a nut top end but low revs it will judder then if u try and leave it on odle it will cut out ive had the idle screw all the way out made a little difference but still cut out went to it yesterday moring started up fine but then idled at 3000rpm and ran fine when i droped the idle again whent back to it later and took it out for a drive and it was back to cutting out again does this when its hot and cold 1.6 chv 2v webber carb automatic choke any help please Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted May 29, 2012 Share Posted May 29, 2012 Checked your dizzy cap / rotor arm???? Might be worth cleaning or replacing. Quote Link to comment Share on other sites More sharing options...
