Guest J.E.E.P. Posted April 4, 2012 Share Posted April 4, 2012 (edited) Can anyone tell me if you can change the valve stem seals on a 1.6 16v EFI engine without removing the head? Eg By using compressed air to pressurise cylinder to hold the valves in place. Cheers. Edited April 4, 2012 by J.E.E.P. Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted April 4, 2012 Share Posted April 4, 2012 You can change the valve oil stem seals without removing the head, I have done loads of them but I have never heard of using compressed air to keep valves in place. Whereabouts are you? If your close enough I could give you a hand or do them for you Quote Link to comment Share on other sites More sharing options...
Guest J.E.E.P. Posted April 5, 2012 Share Posted April 5, 2012 Hi Ian, thanks for the reply. Unfortunately Im in South Wales so a bit far for a hand Im afraid! Im an engineer by trade so not afraid of doing it myself. Just need a few pointers as to which way to go about it. (Valve spring removal etc). Quote Link to comment Share on other sites More sharing options...
