Guest sakuv Posted March 13, 2012 Share Posted March 13, 2012 I changed the oil the roof opening to the engine, does the system bled, andhow to do it? Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 13, 2012 Share Posted March 13, 2012 You should NOT USE ENGINE OIL IN THE HYDRAULIV ROOF PUMP. Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 13, 2012 Share Posted March 13, 2012 Use FORD PART NUMBER1661100, OR, Cross reference this oil to find an Hydraulic Oil of similar type. Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 13, 2012 Share Posted March 13, 2012 Engine Oil and Hydraulic Oil DO NOT MIX. If I were you, I would be inclined to strip the whole system down, and try and flush out ALL the Engine Oil. Then install proper fresh Hydraulic Oil. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted March 13, 2012 Share Posted March 13, 2012 Dont think he put engine oil in it though could be wrong. The system is self bleeding so just open and close the roof several times. I have no idea how or why you managed to drain the system. Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 13, 2012 Share Posted March 13, 2012 The English is a bit broken, but I read the first part as, ' I changed the oil ( for ), the roof opening, to the engine, ( oil). Does the system bled, ( need bleeding ? ), and how do you do it? That was the best that I could make of this jumble:- I changedthe oilthe roofopeningto the engine, If he wasn't changing the OIL for the roof opening mechanism, for engine oil, what OIL was he changing it for? ? Search me.Unfortunately his message return system failed, and with no email address, he is stymied. Or up the creek without a paddle eh? LOL Quote Link to comment Share on other sites More sharing options...
Guest sakuv Posted March 15, 2012 Share Posted March 15, 2012 (edited) hey I'm NOTputting the engine oil system,butt he original ford hydraulicoil. system pipes to burst due to empty,now corrected this, but should let the system weather somehow off? or whether the air off the ceilingto run automatically when closed,open, closed,open?? Edited March 15, 2012 by sakuv Quote Link to comment Share on other sites More sharing options...
