Guest Mejojo Posted March 9, 2012 Share Posted March 9, 2012 Does anyone know where the roof fuse is? Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 9, 2012 Share Posted March 9, 2012 This question comes up regularly and answers MAY be found in the Forums under roof problems etc., BUT, if you open up the boot, and remove the carpet against the near side rear. When you reveal the pump and the aerial, there's a chance you may see two fuses on a loom. If you trace, the looms, one is the electric aerial, - well it is on my Mk6/7 anyway, and the other fuse is the Power Roof. Have a look and let us know how you get on. Cheers, Burt. ( In beautiful North Wales ). Quote Link to comment Share on other sites More sharing options...
Guest Mejojo Posted March 10, 2012 Share Posted March 10, 2012 Hey burt I checked round the roof motor and there's 2 green relay cubes and a grey one. Do you know what the fuse should look like. I'm sure the roof don't work down to something in the electrical circuit rather than the motor. I have a new switch to try too. Will keep you posted. Cheers burt. Jojo Quote Link to comment Share on other sites More sharing options...
