Guest DaveBridgett Posted March 1, 2012 Share Posted March 1, 2012 having problems with my mk5 escort 1.8si charged the battery all the cells chargeing ok put battery back on the car started no problem took the car for a drive approx 50 mile used no electrcs lights radio etc paked the car when i got back home went out later did another 20 mile car started and ran no problem again i used no electrics paked the car for the night making sure nothing left on came out lunch tme next day battery was completely flat.any ideas any one would be a great help Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 1, 2012 Share Posted March 1, 2012 Possibly a hard one to call, without someone looking at it, and physically checking it with a meter. I think you could be looking at a duff cell in the battery. How old is the battery? Is it still under guarantee? If it's under guarantee, you can get it checked out free of charge, and replaced for nothing. If the guarantee has run out, they will still check it free of charge, and ask you to buy a new battery from them. Fair's fair I suppose. Running it without any electrics on, is not a real good guide to the state of the battery. The tool that you need is called a Heavy Dischartge Tester. This is placed across the whole of the twelve volts, and held in position for a few seconds. If it takes the load that the Heavy Discharge Tester is subjecting it to, then you can look somewhere else. I hope this helps you a bit. Quote Link to comment Share on other sites More sharing options...
Guest DaveBridgett Posted March 7, 2012 Share Posted March 7, 2012 got the problem sorted turned to to be a short coming from the switch that operates the roof unbeknown to me the the roof motor was running and that was what flattend the battery lucky that it didnt burst into flames Quote Link to comment Share on other sites More sharing options...
