Guest benguin Posted February 2, 2012 Share Posted February 2, 2012 how easy is it to convert a mk5 to fit mk6 headlights? Quote Link to comment Share on other sites More sharing options...
Guest cossie Posted February 3, 2012 Share Posted February 3, 2012 its easy mate iv got a mk5 and iv got mk6 lights in mine all i did was use the brkets off the mk6 that hold the ligths i changed the bonnet too so it matches the lights . Quote Link to comment Share on other sites More sharing options...
Guest cossie Posted February 3, 2012 Share Posted February 3, 2012 when you remove the indicators as well you will notice that there is a rig where they sit in all i did with mine is get a junior hacksaw and cut small lines so you can then use a small tapping hammer and knock them so they sit flat then your headlight will fit nice and snug to the wing then bolt them up wiring is the same so u don't have to change the plugs to the lights hope this is some help to you mate ... Quote Link to comment Share on other sites More sharing options...
Guest benguin Posted February 3, 2012 Share Posted February 3, 2012 Thats brill cheers mate :-) Quote Link to comment Share on other sites More sharing options...
