Guest no1birdman Posted January 9, 2012 Share Posted January 9, 2012 Hi, is it possible to grease the front bearings, one of nine is makeing a bit of noise but no play, its a pain to change them, Thanks Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted January 9, 2012 Share Posted January 9, 2012 Its rare that a wheel bearing makes a squeaking noise. Check that you don't have brake bind or a damaged cv boot as that will make some noise if no grease is present. The bearing is virtually always damaged during removal and changing it can really hard if its been on for a long while. The second housing tends to stick on the drive shaft and removing it pulls the bearing appart. You would need to do this to get the greese into where it should be Quote Link to comment Share on other sites More sharing options...
Guest theprophet1978 Posted January 9, 2012 Share Posted January 9, 2012 ive just changed my front bearing with a degree of difficulty. Mine was squeeking and very badly like a fool i left it then going round a corner one day had a bad crack and felt like a flat. After pulling over and checking it decided to limp it home and upon removal it had completely shattered bits of bearing everywhere..... Anyway my point being that after changing it for a nice shiny motorcraft one it started to squeak again and the wheel wouldnt rotate properly. It turned out to be the caliper sticking which was a much more pleasing option, so defo worth checking first Quote Link to comment Share on other sites More sharing options...
Guest no1birdman Posted January 10, 2012 Share Posted January 10, 2012 hi. itd def a bearing rumble, just thought there may be a way to grease it up without removeing, Quote Link to comment Share on other sites More sharing options...
Guest no1birdman Posted January 14, 2012 Share Posted January 14, 2012 replaced one side, but it seems very tight, can u over tighten the nut. Quote Link to comment Share on other sites More sharing options...
