Guest john franklin Posted October 24, 2011 Share Posted October 24, 2011 hi again, still have problem (kangarooing) with my mk4 '89 1600 injection i have........ changed fuel filter ,timing is set up as best i can( melted timing light on manifold) ,co is good, plugs are clean and have good spark car ticks over nice and smooth problem arises when driving have seen posts about ESS and ECT sensors but i am new to vehicle. so....... what are they?, where are they? do i have them on mine? and could they cause this problem please help if you can its driving me mad thanks for reading regards john Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted October 24, 2011 Share Posted October 24, 2011 Hi if you have MFI in your's i would change the leads,if still there then rotor arm and dizzy cap...Also make sure before changing and part the firing order is right.... Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted October 24, 2011 Share Posted October 24, 2011 or if its a efi it could be the coil pack on its way out Quote Link to comment Share on other sites More sharing options...
Guest john franklin Posted October 25, 2011 Share Posted October 25, 2011 thanks guys, much appreciated Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted October 25, 2011 Share Posted October 25, 2011 Sounds more like fuel pickup issue. Maybe partial blockage. I would double check that timing is correct by establishing TDC with micro gauge. once done you can re mark the crankcase and set timing using strobe. Also ensure vacuum advance is functioning by removing pipe. It should let no air through when a vacuum is applied. Dizzy cap and arm should be checked as said though it would usually result in poor tickover if worn out. Quote Link to comment Share on other sites More sharing options...
