Guest mic Posted September 28, 2011 Share Posted September 28, 2011 hi one day the electric roof worked fine, the next time i came to use it a couple of days later it refuses to open today i found if i manually half open it then it goes down by the button and likewise for closing.... whats caused that to happen?! thanks Quote Link to comment Share on other sites More sharing options...
Guest demonteddy Posted September 29, 2011 Share Posted September 29, 2011 Could be the fluid level, check the pump, Quote Link to comment Share on other sites More sharing options...
Guest mic Posted September 29, 2011 Share Posted September 29, 2011 sweet cheers. is that in the boot with the pump?!(fluid) Quote Link to comment Share on other sites More sharing options...
Guest demonteddy Posted September 30, 2011 Share Posted September 30, 2011 Yes if you look at it the end near the light you will see two marking low and high, if its low at the top you will see a litle screw undo this and top up. If the fluid is correct try greasing the joints on the hood frame. Could be though your motor is on the way out. Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted October 29, 2011 Share Posted October 29, 2011 the pump may need a repair kit.bout 40 quid on here or ebay i believe Quote Link to comment Share on other sites More sharing options...
