Guest MJS Posted August 28, 2011 Share Posted August 28, 2011 Help! My 96 cabriolet is suffering with a rev problem! When I start the car from cold, the car revs to about 1500 rpm, drops to 1000 then about 500 and runs lumpy all within about 10 seconds. Without touching the accelerator, the car will cut out. When the car is warm, it does not cut out, however sometimes the revs do not drop when changing gear or in neutral, they do the opposite! Sometimes at idle when warm, it can sit at about 1500 rpm. It doesn't do it all the time. I have changed the plugs and leads, replaced the idler control valve, used redex and a carb cleaner and cleaned the air mass sensor. Could it be the ECU? Thanks for looking, any help would be greatly appreciated ) Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 29, 2011 Share Posted August 29, 2011 More than likly a sensor giving a false reading. Possible sensor intermittant short on a sensor such as air intake temp. Either way you will need a diagnostic to check readings and see if any fault codes are present. Assume you replaced the idle control valve with a new one as a second hand one could well be faulty Quote Link to comment Share on other sites More sharing options...
Guest skelly9134 Posted August 29, 2011 Share Posted August 29, 2011 you didnt replace the idle control valve with a knackered one or one of those cheap ones off ebay did you. Also check the earthing strap that goes onto the top of the gear box. I had this same problem and checked everything including giveing the idle valve a really good clean, turned out the earth strap connection was rotten, this is the earth strap for the starter but it is also for the idle contoll valve. I cleaned it up and it was perfect. Its a long shot but it could be your problem. its located on the bolt at the top of the gear box were it joins the engine. Quote Link to comment Share on other sites More sharing options...
Guest MJS Posted September 2, 2011 Share Posted September 2, 2011 Thanks for taking the time to add your comment. I will check it at the weekend. Fingers crossed! Quote Link to comment Share on other sites More sharing options...
