Guest rstescortrep Posted July 23, 2011 Share Posted July 23, 2011 im wanting to tune my engine up and put a twin choke weber but im not sure wat is the best one for my engine. its a mfi cvh 1.6 engine. is there any setting up i need doing once the weber is on cheers Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted July 23, 2011 Share Posted July 23, 2011 You will need the 40's. But its a difficult and expensive set up, I'm going for the twin carb but will be using Bike carbs; its a much more striaght forward set up and relatively cheep. Quote Link to comment Share on other sites More sharing options...
Guest rstescortrep Posted July 23, 2011 Share Posted July 23, 2011 hi wat bike carbs are u using and what manifold cheers Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted July 26, 2011 Share Posted July 26, 2011 Thinking of the CBR600, but will try to source already set up and with maifold, as I'm in France sorting the maifold seperately will not be easy. Quote Link to comment Share on other sites More sharing options...
Guest rstescortrep Posted August 14, 2011 Share Posted August 14, 2011 hi do you know if a weber 28/30 oftm will fit my engine 1.6 mfi cvh cheers Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted August 15, 2011 Share Posted August 15, 2011 Not sure, sorry Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 15, 2011 Share Posted August 15, 2011 Forget putting any carb on other than twin 40 or bike carbs. Even with correct jetting your not going to see any more power than the standard MFI setup. Fit a 2.0 zetec from a mondeo. its cheaper and better Quote Link to comment Share on other sites More sharing options...
Guest adamk Posted August 15, 2011 Share Posted August 15, 2011 My xr2 runs on 34/38 webbers and its 1.6 CVH Hope that helps Quote Link to comment Share on other sites More sharing options...
