Guest madharry24 Posted July 7, 2011 Share Posted July 7, 2011 Hi people i have a h reg 1990 mk 4 escort with a power hood problem the roof wont go up or down unless done manual, i have checked fluid levels they are spot on i have checked the switch that seems to work fine, i have also stripped and cleaned the motor hook that up to the battery and its working so i hook is back up in the boot but not to the fluid reservior . when i press the roof switch i here clicks also slight movement from the motor but not enough to turn is like the motor is stuck yet when i hook the motor direct to the battery is spins fine. does any one know what is causing this Quote Link to comment Share on other sites More sharing options...
