Guest jayden199 Posted May 28, 2011 Share Posted May 28, 2011 please could some one help me every time i leave my car the battery goes completly dead ive put a new battery on ive checked every thing is turned off my car was broken into the steering lock was broken a and there is a red and black wire lose its not connected to the ignition there above the steering colum and i have no idea what there for Quote Link to comment Share on other sites More sharing options...
Guest scotty-b Posted June 5, 2011 Share Posted June 5, 2011 i have the same problem with my mk5xr3i cab, i have to disconnect the battery when not in use, pain in the a**e i know. i think its something to do with the fusebox. will let you know when i get paid so i can sort it. Quote Link to comment Share on other sites More sharing options...
Guest DaveBridgett Posted June 5, 2011 Share Posted June 5, 2011 i hope you have some luck on that ive got the same problem with mine tried everything and still no luck Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted June 7, 2011 Share Posted June 7, 2011 i have the same problem with my mk5xr3i cab, i have to disconnect the battery when not in use, pain in the a**e i know. i think its something to do with the fusebox. will let you know when i get paid so i can sort it. dont mk5,s have a fuse box issue where the water goes into it fooking it up? :unsure? sure i read it on ere some where. Quote Link to comment Share on other sites More sharing options...
Guest jayden199 Posted June 9, 2011 Share Posted June 9, 2011 (edited) my car is also a mk5 i found out that it was the starter moter solinoid staying on all the time i have fitted a switch on the powerlead from the battery to the starter moter as a tempery fix untill i get a new starter moter and it has been working fine i just turn the switch off when i leave the car Edited June 9, 2011 by jayden199 Quote Link to comment Share on other sites More sharing options...
