'92 Mk5 Ecu ??
Guest Rustler
Guest Rustler
Hi....
Just about to reconnect the battery after an 8mth "Lay Up"..(new belts,water pump,brakes,h/lamps etc)... are there any
precautions I should take regarding the ECU memory's etc prior to connection and starting..?
your comments would be appreciated.........Thanks....... :mellow::mellow:
Rustler .... "The Oldest Cabbier" ....
Guest snoopaloopa
Basically, no :smile:
It 'might' want to relearn everything as its been off for a while, so just take it for a good drive and use all the gears for accel and decel etc so it can get all its base settings sorted out.
