Guest br1gg5y Posted May 17, 2011 Share Posted May 17, 2011 Need some guidance on how to determine the cause of the problem. My handbrake / parking brake light remains on. Regardsless of if the handbrake is applied or not. Or if I disconnect the lead to the switch, wiggle the wire, etc. The brake fluid is up to the mark. BUT, If I unplug the 3 wired lead that plugs into the brake servo resovouir. The hand brake light remains off. Regardless of what I do. How do I move forward from here? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 17, 2011 Share Posted May 17, 2011 No sure what car you've got but as a basic rule most fords operate the parking brake light when the brake fluid level is low and it can take a few seconds for the light to go out. The hand brake circuit is fed through the sensor so disconnecting the terminal will mean the light wont work at all.You probably have a sensor thats stopped working or a wiring fault Quote Link to comment Share on other sites More sharing options...
Guest br1gg5y Posted May 17, 2011 Share Posted May 17, 2011 cheers, was not certain if the handbrake and brake fluid level sensor where on the same circuit it is a mk3 escort cab, carb engine with a efi loom as the loom did use to have the connectors ofr the injectors and throttle position sensor etc till I removed them Quote Link to comment Share on other sites More sharing options...
Guest br1gg5y Posted May 18, 2011 Share Posted May 18, 2011 The problem seems to be 2 fold, the float in the brake fluid sensor was stuck at the bottom ot it's stroke. Meaning the copper "hat" on the end of the shaft was touching the 2 contacts. Making the circuit believe there was no brake fluid. Also the switch on the hand brake itself is tempramental. If I remove the cable and touch it to a good earth. The circuit works as expected everytime. If I reconnect the cable to the hand brake. It does not always detect when the hand brake is in the off position. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 18, 2011 Share Posted May 18, 2011 I would take the switch out and see if it can be made to work properly. If not source a second hand one. Theres lots of people breaking cars on here. Quote Link to comment Share on other sites More sharing options...
Guest br1gg5y Posted May 18, 2011 Share Posted May 18, 2011 all fixed. poor contacts and bad earth were the problem. once i unstuck the float on the brake level sensor Quote Link to comment Share on other sites More sharing options...
