Guest spaceman Posted May 3, 2011 Share Posted May 3, 2011 Evening all. 1990 mK4 H Reg EFI XR3i Cabbie without ABS. What size bore rear wheel cylinders should be fitted-19mm or 22mm? Looking on Europarts website and others the two sizes are listed for the same car! There are non-Ford ones fitted at the moment which do not have a letter on the back as per Haynes manual instructions! Thanks Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 3, 2011 Share Posted May 3, 2011 If i remember right they are 19mm on mk4 and the mk5/6 has 22mm. Maybe they list two as this was the crossover between mk4/5. Quote Link to comment Share on other sites More sharing options...
Guest spaceman Posted May 4, 2011 Share Posted May 4, 2011 Thanks Lee 81. Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted May 5, 2011 Share Posted May 5, 2011 Don't know if this helps, but I have just done this on my 4x4, my brother in law gets parts for me and he says this is a constant problem with many cars, he orders both parts, and sends the part he doesn't use back!! Quote Link to comment Share on other sites More sharing options...
