Guest Mejojo Posted April 8, 2011 Share Posted April 8, 2011 Hello all. Is there an easy way to fill the roof tank in the boot. I found with the hole being small it gets all air bubbly. Any ideas? Ta Quote Link to comment Share on other sites More sharing options...
Guest derrick Posted April 11, 2011 Share Posted April 11, 2011 Hello all. Is there an easy way to fill the roof tank in the boot. I found with the hole being small it gets all air bubbly. Any ideas? Ta i did this with my mk4 m8 i used a one man bleeding kit i had lying around or you could make one up with a little plasic bottle and a tube inserted into the cap fill it up turn it upside down and let the air rise then squeeze the bottle to fill you just have to make sure that the tube fits into the hole if not just wrap blue tack around the end and fix it to the tank to make a seal then fill it up? Quote Link to comment Share on other sites More sharing options...
Guest Mejojo Posted April 18, 2011 Share Posted April 18, 2011 Thanks for the tips. That makes sense. I managed to fill it using a lil drink straw but was still a bit messy. I shall do it your way next time. Cheers Quote Link to comment Share on other sites More sharing options...
