Guest redcab81 Posted April 3, 2011 Share Posted April 3, 2011 hi new t all this as well. Got a immaculate xr3i cab mk5 and looking to convert to a 1.8 zetec black top comes complete with throttle body, engine loom, injectors and fuel rail, inlet and exhaust manifolds, leads and plugs,coil pack,water pump, clutch, flywheel,thermostat housing,oil filter,sump My car has immobiliser at moment was thinking of a aftermarket ecu like megasquirt Can i use original gearbox if not what could i use. Anything else i should take into consideration Any advise on other requirements please let me know would be greatly appreciated Redcab81 Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted April 3, 2011 Share Posted April 3, 2011 hi new t all this as well. Got a immaculate xr3i cab mk5 and looking to convert to a 1.8 zetec black top comes complete with throttle body, engine loom, injectors and fuel rail, inlet and exhaust manifolds, leads and plugs,coil pack,water pump, clutch, flywheel,thermostat housing,oil filter,sump My car has immobiliser at moment was thinking of a aftermarket ecu like megasquirt Can i use original gearbox if not what could i use. Anything else i should take into consideration Any advise on other requirements please let me know would be greatly appreciated Redcab81 What is fitted in your car at the minute thus allowing be to point you in the rite direction.. Quote Link to comment Share on other sites More sharing options...
