Guest realcolne Posted March 26, 2011 Share Posted March 26, 2011 hi my mk4 escort cab is sat to high at the back 4" gap between tyre and wheel arch with 15" alloys thought it was the shockers so change them for some new rs turbo ones and its just the same do i get lowering spring nexts or have you any other suggestions Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted March 26, 2011 Share Posted March 26, 2011 Something not right there, are the springs sat in the right place, up the right way and is the rubber ring thing up the right way? Quote Link to comment Share on other sites More sharing options...
Guest realcolne Posted March 26, 2011 Share Posted March 26, 2011 yep everything on right put new one on same as took other off always been that high just dont know why ? starting to think it might have wrong springs on, the wheels are leaning out so wears tyres on the inside Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted March 26, 2011 Share Posted March 26, 2011 I wouldn't even drive the car like that. The suspension angles are going to be way off normal sat that high. Get a decent set of springs from someone like Eibach. Will only set you back around £100. The front springs are longer than the rear ones. It looks like maybe they have fitted front ones on the rear. Quote Link to comment Share on other sites More sharing options...
Guest realcolne Posted March 26, 2011 Share Posted March 26, 2011 never thought about that if they same size just longer then they might well of done that thanks for the help i will get some and see if it drops it lower Quote Link to comment Share on other sites More sharing options...
Guest realcolne Posted April 3, 2011 Share Posted April 3, 2011 http://i446.photobucket.com/albums/qq189/realcolne/DSC00119.jpg took the old springs off and put 30mm lowering springs on thats better the ones a took off were nearly double size of new springs and really stiff Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted April 3, 2011 Share Posted April 3, 2011 Looks right now, is the wheel alignment OK now? Quote Link to comment Share on other sites More sharing options...
Guest realcolne Posted April 4, 2011 Share Posted April 4, 2011 yeah seems to be thanks for the help guys Quote Link to comment Share on other sites More sharing options...
