Guest br1gg5y Posted March 23, 2011 Share Posted March 23, 2011 Is it possible to remove the lenses on rear lights?I have a MK3, and I have a set of MK3 and MK4 lights. The bulb holders form the MK4 set will not fit correctly onto the MK3 pair. I would rather have MK3 set on the car if I can..... so is it possible to remove the lenses and swap the MK3 lenses onto the "bodies" of theMK4 set. Does that amke sense? Cheers, Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted March 23, 2011 Share Posted March 23, 2011 seen the mk4 lens removed and clear 1's put on and re-glued. try them in the bath to make sure they are sealed once you have re-glued them.. hope this help's just be careful not to break them Quote Link to comment Share on other sites More sharing options...
