Guest derrick Posted January 31, 2011 Share Posted January 31, 2011 right guys here my prob my cabbie got broken into a few months ago so i fitted a better alarm imobiliser and delocked the car i now need to replace the stering lock that was snapped can i get a replacement part or would i be better off going to a breakers and getting the full stering set up incl the keys and switches but as ive got a tilt stering wheel ive seen a few in the breakers and they seem to be diffrent to a mk5 so i need a little advice cheers. Quote Link to comment Share on other sites More sharing options...
Guest Tuft Posted January 31, 2011 Share Posted January 31, 2011 I've had two Escorts stolen in the last six months. I got them back. They break the bottom shroud and pop off the ignition switch and use a screwdriver to turn the centre of the barrel. That's it! I found that the steering lock seems to be the same whether adjustable or not. What is different is the plastic shroud on the adjustable type column. Although the MK5 and MK5A have the same position screw holes the MK5A shroud is slightly longer towards the steering wheel and will foul the wheel if trying to fit the later shroud on an earlier car. The later shroud is identifiable by having four lower screw holes (only two are used). If I remember rightly the steering lock assembly is just held in place once the steering wheel is back on. It has a bearing in the upper end and a nylon collar that keeps it all centred. Quote Link to comment Share on other sites More sharing options...
Guest Tuft Posted January 31, 2011 Share Posted January 31, 2011 Forgot to add that you only need to buy the lock assembly if your ignition key barrel is undamaged. I think the airbag type may be different but if yours is non airbag then an assembly off a mk5 or mk5a should fit whether it's PATS or not. Quote Link to comment Share on other sites More sharing options...
Guest derrick Posted February 1, 2011 Share Posted February 1, 2011 I've had two Escorts stolen in the last six months. I got them back. They break the bottom shroud and pop off the ignition switch and use a screwdriver to turn the centre of the barrel. That's it! I found that the steering lock seems to be the same whether adjustable or not. What is different is the plastic shroud on the adjustable type column. Although the MK5 and MK5A have the same position screw holes the MK5A shroud is slightly longer towards the steering wheel and will foul the wheel if trying to fit the later shroud on an earlier car. The later shroud is identifiable by having four lower screw holes (only two are used). If I remember rightly the steering lock assembly is just held in place once the steering wheel is back on. It has a bearing in the upper end and a nylon collar that keeps it all centred. cheers for that tuft ill go to a breakers soon and look now as i dont want to mess about with the lock if i was going to do further damage cheers . Quote Link to comment Share on other sites More sharing options...
