Guest keith29uk Posted August 22, 2010 Share Posted August 22, 2010 hi i wounder if anybody can help me i got a escort cab mk5 with electric windows in front and back,both front windows work and the rear passanger one works but cant get drivers side rear working i have changed motor and swapped switches but still can get it working can anyone tell me if there are relays for these windows and if so were they are regards keith Quote Link to comment Share on other sites More sharing options...
Guest corrie Posted August 25, 2010 Share Posted August 25, 2010 the relays and fuses are in the drivers side kick panel the relays are green if i remember correctly. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 26, 2010 Share Posted August 26, 2010 Also check the wiring connectors in the door, might be worth cutting them out and reconnecting the wires directly to each other, the connectors sometimes play up and stop the windows from working. Quote Link to comment Share on other sites More sharing options...
