just280 Posted August 9, 2010 Share Posted August 9, 2010 hey guys have got to have a new hood fitted to my wifes cab, does anyone know how to remove the rear heated screen so i can put new hood behind a;so is spade tabs come off the heated part of sreen how do you put them back on thanks Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 9, 2010 Share Posted August 9, 2010 Hi, the spade tabs are pull off, push on so that part is easy, to remove the rear glass you have to tease the rubber away from the frame from inside the car, and slowly work your way around taking your time, the window frame is then stapled thru the roof material, just pull that away and then the roof is ready for the next stage of removal, hope this helps Quote Link to comment Share on other sites More sharing options...
just280 Posted August 10, 2010 Author Share Posted August 10, 2010 thanks will give that a try Quote Link to comment Share on other sites More sharing options...
